» Online Classroom   » Celestial Navigation   » Public Discussion of Cel Nav   » cassens-plath bubble horizon altitude corrections
Author Topic: cassens-plath bubble horizon altitude corrections
tkuhns
 - posted August 18, 2024 10:09 AM      Profile for tkuhns           Edit/Delete Post
bubble horizon sun altitude corrections: dip,s.d.& aug. are ignored. star refraction corrections. are used. since sun h.p. is 0.0024 degrees ( 0.14') and since hp x cos.Ha is even less altitude parallax correction can be ignored. are these rules correct for sun bubble altitude corrections? thank you
 - posted August 18, 2024 07:16 PM      Profile for David Burch           Edit/Delete Post
Yes, that is correct. No dip because you are measuring effectively relative to the true vertical, not the visible horizon, and no semi-diameter as you are aligning the centers of direct and reflected views.
But may I ask which model of artificial horizon you refer to? They are fairly hard to find these days.
Does this manual describe your device?
I might add that even though these instruments cost about $2,000 (more than twice the cost of a good sextant they have to be used with), they are intended for use on land, not at sea. Even the very slightest motion of the boat inhibits their usage.
tkuhns
 - posted August 19, 2024 09:59 AM      Profile for tkuhns           Edit/Delete Post
thank you for confirming my bubble sun alt.corrections. I was most interested in the parallax calculation. yes. that is the C-P bubble horizon. they are available from celestaire in whichita, kansas and direct from Germany for $950.00. they are best used from shoreline or an unobstructed hs altitude inland.i teach cel.nav.in the new york power squadron; my students have the most trouble with parallax calculations. moon. next. t.kuhns
 - posted August 19, 2024 10:01 AM      Profile for David Burch           Edit/Delete Post
Sorry i did not mention it but you are right the sun parallax is small and can be ignored for these sights.
