Topic: d-value and d-correction
Martien
posted February 13, 2026 03:38 PM
Just finished quiz # 9 and got the results back. I had several answers wrong, 0020,0023 0024. These were wrong because I assumed that the +/- for the d value as stated on page 100 bottom right also applied to the d correction , which is not the case . On the both charts they are simply indicated as d but they are different and the rules regarding the d-value do not apply to d- correction as I understand it. I had applied this to HC in box 5 and gave d either a + or a minus depending on the degree going up or down. This of course affected the range and away or toward and of course the plots. May this help other students. Martien
posted February 13, 2026 04:09 PM
This was posted in the Public Discussion, and moved here to look into.
posted February 13, 2026 04:17 PM
I will leave this to Robert to check details, but I notice that Lesson 9 is on the moon, and a common moon mistake is to confuse the direction that d-value is moving and choosing a sign that way, when in fact we always care what the direction that the actual declination is moving (not the d-value) to determine the sign of d, which is then the sign of the correction.
The declination can be getting bigger with time (+d, +correction) while at the same time the actual d-value is getting smaller, which just means that the declination is getting bigger more slowly as time goes by, but still +d.
Not sure that is the point at hand, but a good point to remember in any event.
RobertR
posted February 13, 2026 08:40 PM
I think David is on the money here. I can't be sure without seeing your workforms, but your Zn are consistently correct, and your intercepts were off by amounts entirely consistent with a moon d error.
Martien
posted February 23, 2026 12:38 PM
Thank Robert and David, Sorry about the delay in getting back. I redid the work forms and when I have the correct d +/- then my answers are exactly as per the answers of the quiz. I will not make that mistake again. I am enjoying the course very much. Martien
