» Online Classroom   » Tech Support   » StarPilot   » Update DR examples in the manual
Author Topic: Update DR examples in the manual
 - posted August 13, 2004 10:01 AM      Profile for David Burch           Edit/Delete Post
There is an error in the screen capture for the first update DR example in the manuals for all StarPilot products. That capture was done from an initial DR log of 0.0, whereas the example being worked has initial log reading 100. The screen capture shows it is a solution for 123.7 miles run on course 245, whereas it should be just 23.7 if starting at reading 100.
Note also, since we have had questions about it, that the longer example following this one with several course changes in it, is indeed correct as printed. Remember that the course listed beside each log reading is the course that you turned to at that log reading... just as you would record it in a real log book.
