Topic: HBS Prob. 7
Rich A
posted March 22, 2017 05:16 PM
I am unable to find the information for Block 5 of the work form for Vega.
A Dec Deg of 38 is not listed in my HO249 Vol 2. The Dec Deg listed across the top of the pages range from 0-14 and 15-29 degrees.
Am I looking in the wrong place?
posted March 22, 2017 05:46 PM
38º is not in 249. have to use 229, or compute the answers directly. most of these problems will be 229 or computation.
see www.starpath.com/calc for computations, also 229 is online as free download.
Rich A
posted March 22, 2017 06:19 PM
I don't have HO229 series, and didn't see where it could downloaded. Would it be easier to do the computations directly? If so, the Sight Reduction & Pre-computation tool doesn't give the same answers as in the book for this problem.
LHA 311 Dec 38 N a-Lat 37 N
posted March 22, 2017 06:27 PM
remember when you compute to compare with tables you have to use the AP values just as in the table side.
also you will have minutes on the dec.
note that if you choose to use all computation — actually the best solution for the book and for navigation in general — then the approach to the sight reduction can be made more efficient as well, as you would then use actual DR for the computation. this in turn calls for enhanced plotting techniques as well, ie plot from the DR position....
or just use the computation to get Hc and Zn and use normal procedures.
