| ENC object Everything on an ENC is called an "object." There are point objects like buoys or beacons, or line objects like depth contours or entrance ranges, and area objects like the area between two contours or a restricted area. Each object has in turn a set of attributes that describe the object. See ENC attribute See also object catalog |
