| air 1. The mixture of gases comprising the earth's atmosphere. Dry clean air is composed of about 78% nitrogen, 21% oxygen, and about 1% argon. Carbon dioxide makes up about 1/30th of 1%, and there are traces of other gases. A typical sample of air will include variable amounts of impurities such as water vapor, suspended dust particles, smoke, pollen, etc. The amount of water vapor in the air is between 0% in dry or frigid air and 4% in warm moist air, measured by volume. The amount of water vapor in the air is a key factor in the weather associated with that air. Typical water vapor concentration is about 1%. See also atmosphere and WXT ART-13 on humidity. 2. Often used by mariners to refer to the wind, i.e. wind of force 1 on the Beaufort scale (1-3 knots) is called light air. See WXT RES-21 for the Beaufort scale. |
