| Altitude Intercept Called the "a-value," it is the difference, found in the last step of a sight reduction, between the calculated height (Hc) and the observed height (Ho) of a celestial body. It is used for plotting the LOP. It is labeled A (away) if Hc is greater than Ho, or T (toward) if Hc is less than Ho. In physical terms, "a" tells if we are closer or farther from the GP than the assumed position is. An a-value of 20' T, for example, means your true position is 20' closer to the GP than the assumed position is. Abbreviation: a |
