| frost 1. A deposit of interlocking ice crystals formed by direct sublimation on objects, usually those of small diameter freely exposed to the air. The deposition is similar to the process in which dew is formed, except that the temperature of the befrosted object must be below freezing. It forms when air with a dew point below freezing is brought to saturation by cooling. It is more fluffy and feathery than rime which in turn is lighter than glaze. Also called hoar, hoar-frost. 2. The condition which exists when the temperature of the earth's surface and earthbound objects falls below 0° C or 32° F. |
