» Online Classroom   » Celestial Navigation   » Public Discussion of Cel Nav   » question on 120 degree spread between stars versus 60 degrees
Author Topic: question on 120 degree spread between stars versus 60 degrees
briangetty
 - posted February 26, 2022 06:41 AM      Profile for briangetty           Edit/Delete Post
In Section 11.24 of the Celestial Navigation book, on page 174, you say that a 120 degree spread between the stars ensures that (with a fixed error) the correct position is in the center of the equilateral triangle, but that this is not true if the stars are 60 degrees apart. I am having great difficulty in understanding why that is; can you explain the difference?
 - posted February 26, 2022 09:12 AM      Profile for David Burch           Edit/Delete Post
A brief explanation can be seen in this article and in the textbook fig 11.24
https://www.starpath.com/resources2/Bearing_Fix_Accuracy.pdf
The most thorough answer to your question here is to download the free app we provide in this article and experiment with it
http://davidburchnavigation.blogspot.com/2016/07/most-likely-position-from-3-lops.html
see also this one that puts it into play:
https://davidburchnavigation.blogspot.com/2017/10/analysis-of-celestial-navigation-sight.html
